I know they make galvanizing in a spray can, but it doesn't look anything like a hot dipped or electro galvanized part. Anyone have any methods of blending in a weld on a galvanized part? I needs to be painted over so it doesn't rust right away but I'm just curious if anyone has any experience with a paint that looks like a hot dipped galvanized part and a paint that looks like an electro galvanized part. I had an old can of spray paint from Ace that looked exactly like a hot dip but I couldn't find a replacement when I went there looking John 3:16(2) Miller Pheonix 456(2) Millermertic 252Dynasty 210DXHobart 210MVPDoringer D350 SA Cold SawScotchman 350LT Cold SawWebb 10x50 MillWebb 15x40 LatheGeka Bendicrop Ironworker
Reply:BellSouth used this to touch up guards going over canals after welding galv pipes together.http://www.crcindustries.com/ei/prod....aspx?id=18412Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Sherwin Williams makes a spray that is a decent match.Dan
Reply:Cold galvanizing spray contains zinc and is meant to protect the steel from rusting. If you just want the look of galvanized, try silver colored hammer-tone paint. Made by Rust-oleum and others.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:hit it with cold galv spray then a misting of the cheapest silver spray paint you can find.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches. |
