how to setup my pipeline \ refinery welding rig
发表于 2021-8-31 23:28:01 | 显示全部楼层 |阅读模式
any ideas would be awesome thankls
Reply:I respectfully suggest you review the hundreds of posts and responses on this subject.What kind of welding do you plan to do.  Are you going to stay in Kansas?  Will you need a seat for Toto?Your budget will influence your choices.There is no need to re-invent the wheel.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Check this post, 996 replies so far.http://weldingweb.com/vbb/showthread.php...e-welding-rigs You should find LOTS of ideas here.
GMT+8, 2025-12-26 21:30 , Processed in 0.118795 second(s), 18 queries .
