Articulating tv stand
发表于 2021-8-31 23:28:01 | 显示全部楼层 |阅读模式
Got scared when I saw the tv stand prices and my wall isn't flat so I came up with this. Can be positioned anywhere within 72 inches of wall. The tv is like 40 lbs and it holds it like a champ. Cost 25 dollarsSent from my Xoom using Tapatalk Attached Images
Reply:nice work. what size bolts are holding that 40 lb 6' level on the wall?There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Nice, looks very professional. So how often do you stand out on the balcony and watch the TV?  Or do you just put porn on and swing it out so the nossy neighbor with the binoculars has something to see? Last edited by DSW; 02-15-2012 at 01:37 AM..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by ThorsHammernice work. what size bolts are holding that 40 lb 6' level on the wall?
Reply:Have you considered a tilt function? You could fab one based on a center pin to rotate with 2 drilled circular plates and a pin or 2 for position locking.Last edited by bearston; 02-15-2012 at 09:41 AM.
Reply:Do you have some close-up pics?  I would like to do the same thing for a computer on my CNC machine.  My first attempt was a failure, but yours looks like it would work for me.  I would like to see some close ups of your joints if you wouldn't mind.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Originally Posted by bearstonHave you considered a tilt function? You could fab one based on a center pin to rotate with 2 drilled circular plates and a pin or 2 for position locking.
Reply:Pic troubleSent from my Xoom using Tapatalk Attached Images
Reply:Wow, that's quite the reach. Nice for watching tv on the deck... or maybe the neighbors across the street. Did you use any kind of bushings?
Reply:Sweet build.Wait a minute. Where did you hide the wires?Last edited by ToolBoxTavern; 02-16-2012 at 08:34 AM.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:That thing has a heck of a reach.Dave ReberWadsworth Ohio
Reply:Originally Posted by forhireWow, that's quite the reach. Nice for watching tv on the deck... or maybe the neighbors across the street. Did you use any kind of bushings?
GMT+8, 2025-12-26 21:31 , Processed in 0.087676 second(s), 18 queries .
