Dynasty cart
发表于 2021-8-31 23:27:59 | 显示全部楼层 |阅读模式
I finally finished the cart for my welder. It came out exactly how I planned, although the welds didn't come out as good as I wanted, but it's really all in the name of practice anyway.
Reply:Looks good, but why did you lay the casters out so far.  They'll get hung up on stuff alot easier sticking out like that.
Reply:Thanks. I didn't really make it because I need to move it around, I made it more so it's just off the floor. They stick out so much so it will be as stable as possible for when and if I do ever have to move it around, but the garage is pretty tight as it is and my torch, stinger and ground will reach anywhere in the whole garage anyway.
Reply:Nice job.  Add a pneumatic quick connect to a long Argon line and you should be good anywhere in the garage.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by Drf255Nice job.  Add a pneumatic quick connect to a long Argon line and you should be good anywhere in the garage.
GMT+8, 2025-12-26 21:30 , Processed in 0.092228 second(s), 18 queries .
