Beam Job
发表于 2021-8-31 23:27:59 | 显示全部楼层 |阅读模式
Bunch of beams, HSS columns,few full penetration weld moments,Lot of  A-325 bolted shear tab connections. Attached Images
Reply:I had always heard that carpenters were allergic to steel...
Reply:Nice photos!  ahahah and my boss tells me that us welders are allergic to grease, he friggin hates it with a passion if its on pieces that we are fixing.
Reply:Interesting blend of wood & steel in that job there. Architect is making use of everything thing available."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Is the span in photo3 around 20 to 24 feet? Or is it more? It's amazing how open the floor plans can be with some steel.
Reply:I can tell you every day that carpenters don't understand steel at all.    They don't get the fact that we cant just lay it up on our knee and take another 3/8" off it.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by forhireIs the span in photo3 around 20 to 24 feet? Or is it more? It's amazing how open the floor plans can be with some steel.
Reply:The PROPER way to build a house.www.thefusionsolution.com
Reply:Those spans are 22' i layed out a tape on them today.Got a few more pics i,ll upload and post in a bit.
Reply:I like those jobs, if you make the steel they fall in to place.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:More pics this is what below the columns in the 3rd pic of the first post.These are at the garage entrance. Attached Images
Reply:It's a good thing there are engineers to do the math for us. Usually if I design something off the cuff it grows by 300% the second it leaves the shop. Usually we think it has to weigh a ton to hold stuff up. Maybe it's just me though. I make something for my house, then I get it home and I realize it could hold up the world.CERTIFICATIONS:7018M- H.V.O10718M- H.V.O11018M- H.V.O9N10- H.V.O71T-1-HYM- H.O.V100S1 PULSE ARC 0,035- H.O.V100S1 PULSE ARC 0.045- H.O.VER70S-3 PULSE ARC 0.035 H.O.VER70S-3 PULSE ARC 0.045 H.O.VER5554- H.O.V
Reply:nice job all around .wish i had garage space like that. that building isn't going anywhere.........
Reply:When I worked in Palos Verdes Estates, EVERY new house or remodel had steel in it.  Because of the seismic codes out in L.A., the steel was used more for portal frames [for lateral bracing] than in floor systems.  The house being built next door had lotsa both, and neither the carpenters or steel men had any problems with coordination.    They get used to it.
Reply:Originally Posted by Fabn4FunWhen I worked in Palos Verdes Estates, EVERY new house or remodel had steel in it.  Because of the seismic codes out in L.A., the steel was used more for portal frames [for lateral bracing] than in floor systems.  The house being built next door had lotsa both, and neither the carpenters or steel men had any problems with coordination.    They get used to it.
Reply:Probably because they know with out you, they are building the house. lol!www.thefusionsolution.com
Reply:the intersection of the structural members looks a little 'busy' did the engineer spec that fit up?
Reply:Looks like you have some nice work there.The last time I did some welding in a home, It had an addition put on with a little structure like that.  I told them no problem about fire.   My son was there as fire watch.  Slag fell in my shirt pocket and caught it on fire.    Home owner saw it....I had long johns on so I didn't get burnt.It was the only problem we had.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I wish I could find the rest of the picts of this project.36 12' tall columns in the basement alone. Upper beams are W12's IIRC. We cut out 2 columns later and installed 2 W36 beams to span the removed columns. Wish I could find the picts of that. I didn't do any of the welding. We did all the footing work and we helped our friend who did the steel set the columns and beams since we were on site anyways for other stuff. Attached ImagesLast edited by DSW; 01-30-2012 at 07:41 PM..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by fdcmiamithe intersection of the structural members looks a little 'busy' did the engineer spec that fit up?
Reply:Couple last pics of the top beams going in with my buddy crane truck. Attached Images
Reply:Nice work. I would hate to have to pay the property tax bill that place is going to have .Miller Synchro250 bought new 1997Millermatic200Miller Bluestar 2E . AC/DC 16hpBluestar 2E , DC Miller Thunderbolt225 AC/DC ArcLongevity 60 plasma
GMT+8, 2025-12-26 21:32 , Processed in 0.093012 second(s), 18 queries .
