Linde 330 AB/P w/ Lincoln LN25 suitcase?
发表于 2021-8-31 23:27:57 | 显示全部楼层 |阅读模式
I just got recently purchased a 330 AB/P and it seems to be working fine.  Its an old machine but I got the complete setup and a nice miller water cooler cheap.I also just picked up a Lincoln suitcase  LN25 at a swap meet.The suitcase will work off the 330, which is CC [I think] with solid core and innershield steel wire, but will it work with aluminum wire?  I usually use machines CV with aluminum wire.I am just starting out doing small stuff in my garage and money is tight- hence piecing my equipment.The guy has 2 more 330's that dont work.  How much copper is in them?  I can pick them up pretty sheap I think.  the unit weighs over 800 LBS!Thanks all!Pete
Reply:We'll assume that's a typo and you mean Miller, not Linde.There is substantial copper in them, but test them first.  Consider throwing them up on the For Sale forum intact as some folks may want them.Do part them out since you can use spares if you scrap them, and if you have any extra pieces post in the For Sale forum. What's your location?
Reply:No I meant Lindehttp://cgi.ebay.com/ws/eBayISAPI.dll...m=180644784233Its green and that is the only difference I can tell between the Miller version.I'm in southern CT.Pete
Reply:Don't know about running the LN-25 on a Linde, but don't do it on a Miller 330 A/BP! It will take the contactor out in about 30 seconds of arc time. It's in the manual of the LN-25.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I didn't know Linde was among the remarketers for the 330.I'll keep that in mind when scavenging.
Reply:Thanks- this was the answer i was looking for.maybe ill throw the LN25 on the -bay pete
Reply:Throw it up here first. Does it have the gas solenoid contactot with it?Miller Pro 30068 SA 20064 SAF 300305 G Lincoln gasserMiller 210
Reply:it does, but i have not tested it yet.
Reply:You could probably sell it to a fellow member here pretty easily.Miller Pro 30068 SA 20064 SAF 300305 G Lincoln gasserMiller 210
Reply:Originally Posted by robphillips00You could probably sell it to a fellow member here pretty easily.
GMT+8, 2025-12-26 21:30 , Processed in 0.074761 second(s), 18 queries .
