cooler parts
发表于 2021-8-31 23:27:56 | 显示全部楼层 |阅读模式
I visited my local surplus store and found 2 good items.They had plastic cylindrical flow meters about 12 inches long and 1 inch diam.1 to 15 gph water.   They also had a themometer which was a flow-throughstyle made for water.  Has a alcohol /glass element.  Has water inlet on one end and output on other. and its a panel mount style !The flow meter can be dia assy'd in case I have to adjust the scale.  It has a brass"pea"  which levitates in the conical bore.  I can make a new one to change the scaleif I need to !  Cool! Tim
GMT+8, 2025-12-26 21:30 , Processed in 0.097081 second(s), 18 queries .
