judge me if you can :D
发表于 2021-8-31 23:27:56 | 显示全部楼层 |阅读模式
as i said that i was learning myself to weld, so here are 2 welds that i made today...i would like you to see if they are good...since you people know it best butt weldfillet weld stick weld~80A AC6013 rod...thats it
Reply:Is that 1/8" 6013, if it is 1/8 try running at 110-115 amps. You could slow down your travel speed a bit. The ripples look a little pointy.
Reply:Looks good, but you might wanna turn it up a little, and work on being more consistent/steady[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:they are 3/32" 6013, so i need to slow down a little bit??? am i right???
Reply:Definately slow it down and work on consistancy. Also are you right or left handed? Looks like your going from right to left which makes me think your a south paw. If right handed trying moving left to right
Reply:Your butt weld doesn't look like butt even though it has a little butt on the right hand end!(complete with little butt cheeks!)Judge not lest ye be judged !You may have to turn the other cheek though ....
Reply:travel speed. heat looks good from my house. Always room for improvement but those would pass a visual on my jobs.Weldanpower 225 G7Ironworkers Local #24
Reply:Not sure where u live but if comm college is cheap go take a class.  I took several when I lived in CA.  At $15 a unit it was great as i burned through more $in rod than I paid in tuition.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:i live in Macedonia, i dont know where i can go to class, and what is even worse, i dont know where to look for that... :/
GMT+8, 2025-12-26 21:29 , Processed in 0.092612 second(s), 18 queries .
