Going to school for welding/fabrication
发表于 2021-8-31 23:27:51 | 显示全部楼层 |阅读模式
Will I be able to find a job easily after I graduate from the class? Are welding schools good with placement? What kind of jobs do graduates usually start with.
Reply:Originally Posted by tj1994Will I be able to find a job easily after I graduate from the class? Are welding schools good with placement? What kind of jobs do graduates usually start with.
Reply:It seems that a common piece of advice on the forum is to look for a position as a welder's helper after graduating if you are having difficulty getting a welding position.
Reply:School is a good place to start, and having the degree can get you in the door, but being able to weld is what gets you the job!- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:Originally Posted by shovelonWhat school? What class? What processes? Is the school an approved AWS test facility?
Reply:How much does a welder's helper make? Around 12-14 an hour? And do they do any welding?
Reply:Originally Posted by akatzIt seems that a common piece of advice on the forum is to look for a position as a welder's helper after graduating if you are having difficulty getting a welding position.
Reply:Originally Posted by tj1994How much does a welder's helper make? Around 12-14 an hour? And do they do any welding?
Reply:Originally Posted by tj1994Pretty much all welding processes and the school is an approved AWS test facility. It is a good school.
GMT+8, 2025-12-26 21:29 , Processed in 0.072342 second(s), 18 queries .
