todays good luck
发表于 2021-8-31 23:27:49 | 显示全部楼层 |阅读模式
was heading to do a job to and the axle broke under my 96 sa 250 Attached Images
Reply:So.... any internal damage?Miller Performance AD Helmet - Camo Edition Soon to have: Jackson HSL 100 - Forest Digi CamoMiller Thunderbolt AC/DC((Currently at welding school))
Reply:If thats all the damage i say you got lucky.    You can get aftermarket sheetmetal for them, even stainlessVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Lets see what broke on the axle/trailer...??  also, not to be a prick, but is that an uncapped cylinder in pic 2??
Reply:Sorry to hear about that.  A guy I know was chasing some P'sOS that just stole his scrap, and rolled his SA250. Yours looks in mint condition compared to his. The frame was all wacked out and LOTS of other damage.Warning: If that's your regulator still attached to that cylinder......... you're new here, so get prepared and put on that fire proof suit! You are about to be FLAMED, and prolly bad!!! Just sayin......"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Where's that popcorn-munching icon when you need it?
Reply:i had to hook the cylinders up to cut the tongue off the trailer we couldnt get it to unhook , i dont think anything internal messed up but havent tried to crank it got to change all the fluids yet . were can u get new skins from
Reply:More questions.....  How fast were you going?  How far did the tire go, and did it hit anything??  Looks like you could have drug it a bit before getting stopped, but looks like it could have been MUCH worse..  I hope you can atleast get her functional again without too much $$, sorry about your luck, but curious to see the failed part....
Reply:i will get some better pic of it in the day time it had a mobile home axle under it .i just order the materials to  build me a bed for my 05 dodge to put this welder on
Reply:i was running about 45 going in to a turn
Reply:Ouch!!  Well, hope it turns out to only be cosmetic so atleast you can keep earnin....
Reply:Insurance? I hope...(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Originally Posted by redrocketi had to hook the cylinders up to cut the tongue off the trailer we couldnt get it to unhook , i dont think anything internal messed up but havent tried to crank it got to change all the fluids yet . were can u get new skins from
Reply:MILLER KILLER ???????????????  Did MILLER kill that LINCOLN?????  BLUE MILLER KILLER  BLOB!
Reply:Bills welder repair is where i recommend.   A LOT cheaper than you would think too.Might want to try and bar it over by hand a bit first.   DO NOT use a breaker bar use a ratchet.   just to make sure the cylinders are clear.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:i change all the fluids today and its running fine just got to put a new body on it . i got a 88 sa250 thats got a good body on it  but it runs and i dont want strip it down all it need is a injection pump. i want to get th ss body kit for it
Reply:last time i looked into it, the price was under $500Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-26 23:13 , Processed in 0.093036 second(s), 18 queries .
