Well, except for the tig skills and the machine shop with all the stuff to do this right... I had to replace a sprocket on a 3.5" dia shaft, but it was worn undersize, and the new part would not fit properly. Having never done this before, and since I don't have the equipment for the job, I said: "I can build up that worn shaft with weld, and turn it back down to size." I made a couple of triangles with 2x2 angle, and welded them to the wall so that a straight edge sat nice across them and the undamaged part of the shaft. I used these as a guide to run beads of 7018 for buildup. I then turned the motor on to spin the shaft, and cut the welds down with a file laid across the two angles. I used several clamping setups, and another triangle brace to reduce the chatter, that I didn't get a pic of, but bottom line is, it worked. This is slow speed stuff (60 ish rpm's) and not ultra precise, just need the sprocket to fit tightly so it isn't working on the shaft all the time. The two piece sprocket offered a little fudge factor as well. I saved alot of $ and time compared to replacing the shaft , and my wheels are turning now,(pun intended), as far as maybe making some better portable setup to do this job. Something with a hand wheel, and a real cutting tool...Sorry for the cell phone pics, it's all I had.And, just for the record, the hammer tracks and torch gouging were done by the guys who removed the old stuff, not yours truly.Any suggestions for improvement would be welcome. Attached Images
Reply:I must be doing stuff the hard way.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I like it. I like it a lot. Saved tons of money, and lots of time. The end result was a workable solution to an obvious problem. whats not to love.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Nice job. I like it!DavidReal world weldin. When I grow up I want to be a tig weldor.
Reply:Thanks for the kind words guys. It was a good feeling to pull this off. And Zap, all kidding aside, although it never crossed my mind at the time, I probably got the idea that I could do this from looking at all those shingle roller repairs. Thanks for the inspiration.
Reply:Well color me impressed, that's probably one of the more ingenious ideas I've ever heard of.Have we all gone mad?
Reply:What color do you want?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home. |
