DualShield Welding
发表于 2021-8-31 23:27:46 | 显示全部楼层 |阅读模式
Hi there every one hows it going. Its been a few years since my last post on here but I have been reading all of yours and the tips are awesome and the projects so thanks for thatI have a question about dual shield welding. I have an inter view next week and will need to be able to weld 3/8's plate in a 3G vert up hill. I have not ran that stuff in over 3 years what would you guys requimend for setting on the welder? What volts and wire speed work best?I have run NR 232 and have had a cert in it with 3G about four years ago but most shops do not run it they like the flux core with the gas. I come from a blacksmith, ornamental welding and fabrication background for a number of years. As of now I am looking to brake into the world of structural welding. So any tips you guys may have towards Dual Shield welding I would love to hear them. thanks for reading and keep the sparks going Sean
Reply:Here is what I have in my notes....Stainless 308 on a Lincoln PowerMig 300Horizontal 25.7 volts 298 wireVertical 24.5 volts 258 wireMiller machine with carbonHorizontal 26/28 volts 240 wireVert 23.5 volts 210 wireOverhead 25 volts 230 wireGood luckUA Local 598
Reply:What brand of wire? What size of wire? CO2 or C25? It all makes a difference.
Reply:I believe it was c25 with .035 wireUA Local 598
GMT+8, 2025-12-26 21:29 , Processed in 0.110339 second(s), 18 queries .
