New radiator for my Miller radiator 1?
发表于 2021-8-31 23:27:44 | 显示全部楼层 |阅读模式
I'm refurbing an older miller radiator 1 (tig cooler). I started to fill in some leaks that poped in the OEM radiator in the unit, but after a few cycles of brazing and pressure testing i have found that there are too many holes to patch and its not worth my time to try and save it.Can anyone tell me of a transmission cooler or oil cooler that will fit into the 11' x 11' spot inside this machine? I would like to keep the machine fully inclosed and not have anything bolted to the outside if possibe.OR do you guys think a long coil of 3/8 copper tubing will the be enough to properly cool the coolant?Thanks!
Reply:try the good autozone.  I picked up a heater core out of something to build my cooler it was like $30 I just went to zones  ww and searched the words heater core and started clicking on them. some will have the size you don't have to put in a specific car it will bring up all they carry
GMT+8, 2025-12-26 21:29 , Processed in 0.069039 second(s), 18 queries .
