more work pictures
发表于 2021-8-31 23:27:40 | 显示全部楼层 |阅读模式
pump skidsweighed in at 12klbs each 48" 4 peice 9048x30?"spool with a custom 7' reducer made from flat stock same spool loaded and ready for delivery (not me in picture)Last edited by Fishinsin station; 02-26-2012 at 12:08 AM.UA local 32Team weld-coolTeam miller elite tack upMiller pro-staff
Reply:Wow!! Awesomeness [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Very impressive! When are they going to let you work on the big projects?It looks like mig welding? Any close ups of the welds? How thick is the material?
Reply:Lol looking forward to getting back to normal sized pipe 4 6 8" we use mig and tig mostly pulse fill caps with short arc roots, miller pipepros and one pipeworxUA local 32Team weld-coolTeam miller elite tack upMiller pro-staff
Reply:Wall depends on sch of pipe, between .260 and .50UA local 32Team weld-coolTeam miller elite tack upMiller pro-staff
Reply:Great pictures. Thanks for sharing.
Reply:Great fitup, but I wanna see some weld pics!!!!
Reply:Here is some of my weld pics just so you don't think I'm hatin.Holy OVERLAY!!Last edited by SR20steve; 02-26-2012 at 01:45 AM.
Reply:That over head crane hung roller is the cats pajamas.   im going to have to file that in the mental file if the need ever arises.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:awesome work!Local 597
Reply:Steve what's up with the overlay?UA local 32Team weld-coolTeam miller elite tack upMiller pro-staff
Reply:Were not allowed to 'Hi-Lite" our caps :\ on pipe
Reply:Originally Posted by Fishinsin stationSteve what's up with the overlay?
Reply:Originally Posted by justinTWere not allowed to 'Hi-Lite" our caps :\ on pipe
Reply:Interesting, never seen anything like that beforeUA local 32Team weld-coolTeam miller elite tack upMiller pro-staff
Reply:Originally Posted by SR20steveIt's stellite, it's like hardface. Gotta TIG it and we use like 3/16 rod and crank up the heat. It's a cross that's mounted in a highly abrasive service. I absolutely hate doing that overlay, I have to wear two pairs of stick welding gloves and be careful I don't rest my coolant lines on the smoking hot fitting.
Reply:Originally Posted by Showdog75Been there done that,shop I worked at in the past did a lot of stellite tig overlay.I'd bet I've welded 4000lbs of 3/16" satellite 6 and 12. We rebuilt feeder and discharge valves for a plant that made cellulose(spelling?) food filler. The big ones were 27" in diameter and the small ones 21". Big ones would usually take 120lbs+ and the small ones 70 to 80lbs. Minimum 300° preheat up to 500°. Fun stuff,not.btw its not like hardface it's more like super hardface.
Reply:the overlay,- do they make a spool for a feeder for that?Last edited by citizen smith; 02-26-2012 at 08:40 PM.Reason: added referenceLocal 597
Reply:Very professional! Great workmanship. Just wondering, on the pump discharge side is there drain valves ? I hate when these engineers draw this and do not provide drains above the triple duty valve. Maybe in this case they are not needed but I hate breaking flanges apart and dumping water or glycol mix on floor. GREAT UNION WORK!!!!!!!!!!!!!!!!!!!!!!
Reply:Originally Posted by citizen smiththe overlay,- do they make a spool for a feeder for that?
GMT+8, 2025-12-26 21:30 , Processed in 0.091190 second(s), 18 queries .
