easy construction of a positionerThe wooden board is the arm restpositioning a housing to be weldedHave a nice welding dayDemawww.ecomec.ch
Reply:Looks good iam just unsure of what it is for. Are you building aresurfacer for the rotors?
Reply:He made a positioner like this...For doing welds like this...http://all-a-cart.comWelding Cart Kits and accessories
Reply:Nice job.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Positioner looks great. You've thought of everything, including an arm rest. Is that a DC gear motor? ZTFab, nice welds!
Reply:Ok Makes perfect sense now. Thanks for the info ZTFab.
Reply:Nice. I made a similar positioner using a motorcycle disc and a turner from a bbq rotisserie motor/gearbox. Yours totally blows mine away, mine was a one use solution for railing pedestals. Yours is much nicer and better thought out.Mike
Reply:Originally Posted by ZTFabHe made a positioner like this...For doing welds like this...
Reply:Is a 400 V AC motor with Electronic Speed Control regulator,with inversion of rotation by foot pedals (at the bottom of the first photo), I even use it for the drill and lathe
Reply:Originally Posted by forhirePositioner looks great. You've thought of everything, including an arm rest. Is that a DC gear motor? ZTFab, nice welds! |
