Pin puller
发表于 2021-8-31 23:27:39 | 显示全部楼层 |阅读模式
I needed to pull some 50mm x 120 mm pins from some shipping flatracks. The pins are blind which required pulling them. I made a small tool from some scrap I had laying around. I started by making adater that will accept a 12mm x 1.75  socket cap screw and allow a threaded bolt on the other side. Basically I drilled a 1/2" hole though some 1-3/8" round bar. I then drilled three quarters the way though with a 3/4" drill. I bored to final dimension and cleaned up the bottom. I then tapped the piece for 7/8-9 thread. Photo 1 to 3.I then dug out the rest of the bits from the scrap bin. A couple pieces of tubing, a 7/8" square bolt (no idea where I got it), a thrust bearing and some plate. I did have to spring for a nut and washer.Photo 4: I had to chase the threads in the pin. They were slightly undersized. This really caused me grieve when I was trying to identify the thread. It looked like a 12mm course... but wouldn't accept one.Photo 5: The the adapter is bolted on.More usage photos in the next post. Attached ImagesLast edited by forhire; 02-25-2012 at 10:38 PM.
Reply:I had to pull the pins in two pulls due to the shortness of the bolt. The first pull takes it about 1/2" out. The second longer tube finishes it off. It took a lot of hard turning. At least I didn't break any bolts. I have four more to pull on Monday. I'm sure there is a 100 ways to do this. I thought maybe someone would find the adapter and easy solution. I wish I had a porta-power. Attached ImagesLast edited by forhire; 02-25-2012 at 10:41 PM.
Reply:Forhire, you make some pretty trick $hit man! "Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Your square bolt is a out of a bridge clamp (heavy service clamp)Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Originally Posted by Stick-manForhire, you make some pretty trick $hit man!
Reply:Originally Posted by forhireI think your right. I have a few of those clamps, I thought it look familiar. Luckily none of my clamps are missing the screw.  I found this one in a 5 gallon bucket of junk that I bought from an old timer a few years ago. I always try to go shopping in my junk pile before I buy new.
Reply:Thanks for showing your puller - that was a great idea. I have some pins on a excavator to pull and this will be a to do then without messing things up. Now to find a machine shop to build it for me , thats one trait i never learned .
Reply:Most of the pins I encounter are not drilled and tapped, but also not usually in a blind hole.The adapter is nice.   I keep seeing reasons why I need a lathe.
Reply:yea porta power with hollow center ram is the way i do it .   but in a pinch i'd of gone with your method.
Reply:Originally Posted by Swamp ratThanks for showing your puller - that was a great idea. I have some pins on a excavator to pull and this will be a to do then without messing things up. Now to find a machine shop to build it for me , that's one trait i never learned .
Reply:forhireYou make neat stuff. What is it you do (meaning are you an engineer-welder-tool and die) or what can't you do?Dave ReberWadsworth Ohio
Reply:Originally Posted by ReebsforhireYou make neat stuff. What is it you do (meaning are you an engineer-welder-tool and die) or what can't you do?
Reply:Originally Posted by Swamp ratThanks for showing your puller - that was a great idea. I have some pins on a excavator to pull and this will be a to do then without messing things up. Now to find a machine shop to build it for me , thats one trait i never learned .
GMT+8, 2025-12-26 23:12 , Processed in 0.093201 second(s), 18 queries .
