Welding machine problem
发表于 2021-8-31 23:27:31 | 显示全部楼层 |阅读模式
hello all I have a Lincoln 100 HD that i got from Home Depot about, O i dont know, 10 years ago works awesome but just the other day i was welding up something and i herd a pop and my wire feed is on like warp speed, so i replaced the wire feed switch thingy, still didnt fix problem so then i baught a new circuit board and replaced it, and still didnt fix the problem... has anyone seen or heard of this hapening if so please help. my next step is to take my machine in and get them to look at it with a $80 per hour fee....
Reply:Are there resistors across the motor terminals?Miller Dynasty 200DXMiller Spectrum 250DMiller Millermatic 200Bunch of old blue dinosaurs....
Reply:Sounds like you are getting full power to the wire feed motor. The controller board was a good first guess.Look at the back of to the filler-wire speed control potetiameter (volume control). See if one of the wires has come off. There should be 2 wires, though there may be 3. If possible, disconnect the pot from the circut and check the overall resistance, and wiper functionality.Remember that the wire speed is based on the power setting first and then the wire speed control only fine tunes the feed rate.Last edited by mike837go; 10-10-2013 at 01:13 PM.Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:yes, the wire speed control was changed to a new one and the wires are soldered to the potetiameter, i looked and nothing wrong looking but i gave up and sent it to a lincoln repair shop. Thanks for the info guys
GMT+8, 2025-12-26 21:32 , Processed in 0.083959 second(s), 18 queries .
