Locating old style TIG cup
发表于 2021-8-31 23:27:26 | 显示全部楼层 |阅读模式
Hello!  This is my first post.I have an old air cooled 150 amp Vis Arc II TIG torch that was sold by Air products.  I broke my last cup and can not locate another.  Is there a source for consumables for old torches?   I am pricing new torches but being a CRB (Cheap Rat Bastard)  I would like to find a few cups to hold me over.  I'm using this on a Sears HF arc stabilizer attached to my Lincoln AC/DC 225 tombstone welder.The thread is a 1/2-28.Here are some photos.Thanks,ChrisLast edited by Shadowdog5000; 05-21-2011 at 11:28 PM.
Reply:ebay china torch ! i picked up #9 weld kraft style with a gas valve for $25
Reply:If you check with F & M / Mafco (based in the Greater Cincinnati area) or with Weld Plus (also in the same area), I believe they will be able to serve you. I worked for several companies that used that style torch and both of these distributors took care of them. They both have web sites.
Reply:Found it(with some help from a welder)!  Even found someone who sells the torch brand new.The nozzles are South weld and sell for $6.99 for a 10 pack.Main web of eastern  http://easternweldingsupplyofohio.com/products.htmEaster tig section,  VisArc torch on last page:  http://easternweldingsupplyofohio.com/pdf/Weld-It.pdfSouthweld website: http://jeffwhitlowcountry.com/doylessupply/Southweld TIG catalog (on Page 18) http://jeffwhitlowcountry.com/doyles...IG-CATALOG.pdfInexpensive nozzles http://www.atlweldingsupply.com/Tig-...s_c_837-1.htmlThanks,ChrisLast edited by Shadowdog5000; 05-22-2011 at 10:25 PM.
GMT+8, 2025-12-26 21:31 , Processed in 0.074556 second(s), 18 queries .
