Miller XR push pull/Powcon 400SM
发表于 2021-8-31 23:27:26 | 显示全部楼层 |阅读模式
Is there any reason the two wouldn't work together? Both 14 pin connection. My current wire feeder is a Powcon PD60, which I was told is a relabeled miller wire feeder. I'm looking for this to be my start into aluminum welding, didn't want to get a spool gun and wish I had a push pull and a pretty good deal came along.Powcon 400SM2-PD60 wire feedersMiller XR controlAlumapro push/pull gunSpeedglas 9100xBFH
Reply:i think powcon had it's own 14 pin before it went with the miller 14 pin, so if i were you i would be sure to get a miller 14 pin item and plug it in before buying.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:If that ends up being the case, can the plugs be changed?Powcon 400SM2-PD60 wire feedersMiller XR controlAlumapro push/pull gunSpeedglas 9100xBFH
Reply:As long as the signals get to the right places I would assume that the plug can be changed. I would get a pin-out diagram for each plug and see if everything can just be switched to a different plug
Reply:If it needs a custom adapter cable these folks may be the ticket:http://www.justarc.com/powcon.htmLast edited by farmall; 05-11-2011 at 10:23 PM.
Reply:Originally Posted by farmallIf it needs a custom adapter cable these folks may be the ticket:http://www.justarc.com/powcon.htm
Reply:Well, it seems that my concerns had no cause.......the miller plugs directly into the powcon and didn't blow up when I turned it on. On another note, I'm pleasantly surprised at how "new" this thing is, not a scratch on it, very clean, everything is in great shape so far. Hell, when I opened up the side panel it had that new car smell to it still. The gun that came with it is the XR alumapro gun. This was the first pleasant surprise I've had from an ebay purchase. Can't wait to get using it.Powcon 400SM2-PD60 wire feedersMiller XR controlAlumapro push/pull gunSpeedglas 9100xBFH
GMT+8, 2025-12-26 21:31 , Processed in 0.106122 second(s), 18 queries .
