Using linde for tig
发表于 2021-8-31 23:27:26 | 显示全部楼层 |阅读模式
Im using an old as moses linde for tig practice at work so my switch is used for high frequency starts and constant non variable heat plus there are two remote boxes Im hooked to for power/gas and heat control.  Im not used to this kind of set up specially with the torch being air cooled though I like that the neck is bendable.  Any advice on handling something like this since Im used to a liquid cooled miller digital set up with variable heat control through a foot pedal?
Reply:An assistant ?Weldandpower Lincoln 225 AC,DC with Briggs 16hp gas engine.WW2 era Miller TIG.
Reply:Originally Posted by GBMAn assistant ?
GMT+8, 2025-12-26 21:31 , Processed in 0.098563 second(s), 18 queries .
