Tool to grind weld
发表于 2021-8-31 23:27:17 | 显示全部楼层 |阅读模式
To start, I am a very novice welder.  I have a 1/4" die grinder. Is there a tool I could use that will grind down ugly welding?  Something more aggressive than sanding disk.  I have to get into a small area.  Thanks,Brad
Reply:what are you welding with, and what are you welding on, and how small is a small area to you?There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:I need to remove some, I don't know what to call it other than big ugly welding.  the welding is done.  It is on the frame horns on a geo metro.  I want to spray metal protection on it, but I want to clean it up.
Reply:Die Grinder carbide Burrshttp://www.carbidebur.com/shapes/burs.htmYou can also find them at the Box storesEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I also suggest the rotary files.
Reply:Send a pic of what you have to get into bud. That will help with ideas. Carbide burrs are good sometimes, but in the hands of a novice they will jump around when they catch two edges or roll off a lumpy weld and just booger up everything. A pic would help. I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by The NoofI need to remove some, I don't know what to call it other than big ugly welding.  the welding is done.  It is on the frame horns on a geo metro.  I want to spray metal protection on it, but I want to clean it up.
Reply:Originally Posted by SquirmyPugWhat did you weld? A grinder and paint will NOT make an ugly weld a good weld.
Reply:Originally Posted by walkerNo amount of welding will make a Geo Metro good though, so he should be fine.
GMT+8, 2025-12-27 01:20 , Processed in 0.068742 second(s), 18 queries .
