Plastic Chopper Knife..Guillotine
发表于 2021-8-31 23:27:12 | 显示全部楼层 |阅读模式
This is a guillotine that cuts scrap plastic before re-cycling..The cutting edge was shot so we made a new one out of tool steel..The main plate is just regular cold rolled..Got it REAL sharp and then welded it to the main plate..You should have seen the old on we replaced..It would not even cut butter!I used 309 stainless and it is working just fine!I kept the welds under the surface so no grinding/blending was needed..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Had a little hiccup just left of the dime in the first pict didn't you Zap? Looks like you dipped down about a 1/64". When I 1st read the title I read it as you were working on a  "plastic knife", not a knife for cutting plastic... and I thought "OK now I've seen him weld everything..." Nice work as always..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I think I sneezed.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:What kind of tool steel, what heat-treat state, and how did you put the edge on? Just curious; a while ago I found a piece of scrap steel, about 2.5" x 0.5" x 8'   IIRC and it is a proprietary form of M-3. Haven't yet thought of a use for it.
Reply:Originally Posted by Oldiron2What kind of tool steel, what heat-treat state, and how did you put the edge on? Just curious; a while ago I found a piece of scrap steel, about 2.5" x 0.5" x 8'   IIRC and it is a proprietary form of M-3. Haven't yet thought of a use for it.
Reply:Really nice job!!!!
Reply:Excellent Work ZapBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2025-12-27 01:21 , Processed in 0.193393 second(s), 18 queries .
