100% woodfired bbq grill!
发表于 2021-8-31 23:27:12 | 显示全部楼层 |阅读模式
Hello everybody!Today i orderd the 50kg of steel i need for my first (serious) weldingproject.It will be a woodfired bbq grill for the catering company i own in the netherlands.Most parts are made of 3 mm thick steel plateMonday the steel will arrive so then the fun part will begin!Here is a cad drawing i madeEnjoy!Pieter
Reply:Cool, can't wait to see pictures of you cooking with it!
Reply:so will you be burning a fire else where and feeding the hot coals into the bottom draw of this cooker?
Reply:There will be a wood fire in the back part of the grill. The hot coals can be pulled underneath the grid
Reply:Today the steel arrived, not everything was
Reply:Thesteel arrived today, not everything was there though...Wensday the missing parts will be here too!
Reply:looks neat! Looking forward watching this build.
Reply:Sounds good. I'll be watching your progress! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:The first welding is done!The backpart and the two sides are welded together.I think i pick up the grinder tomorrow and redo some of the welds...This is the best weld:
Reply:I would like to make something  like that but foldable and portable. And by portable I mean it in the european way of the word PORTABLE. That is, I can keep it in the trunk of my van, not pull it along like some of the portable BBQ's i have seen here.I will keep an eye on this proyect just in case I can get some ideas from it!Good luck!
GMT+8, 2025-12-27 03:10 , Processed in 0.090218 second(s), 18 queries .
