Powcon 300sm wirefeeders pd10,20 etc.
发表于 2021-8-31 16:58:42 | 显示全部楼层 |阅读模式
Hey guys i need to know if the pd 10,20 and 30 can work or be adapted to workWith the 300sm. I have a lead on a cheap pd10. Also any manuals for those feeders would be great.
Reply:Most of the manuals are on the ARCON web site, The power drive 10  should work if it has the right plug on the cord.If not it can be changed. The powcons work backwards. a closed circuit in the feeder turns the welder output off. open and it has output. You will know because the ticking stops.
Reply:Ok great. Thank you, that info is a big help.  But website not wrkn.
Reply:Looks like it has crashed, should be up in a few days.Send me a PM if it doesn't
Reply:It seems that the Arcon site still does not work!
Reply:Arcon's site is down because Arcon has been sold (partly).  They branched into welding training, and then metal fabrication training, and now safety training.  The manufacturing operation has been sold to Mirabel Industrial Welding Equipment.Mirabel's site isn't up quite yet, but here is a link to the PD20 manual (I don't have one for the PD10): https://www.dropbox.com/s/4v7ejsy21s...anual.pdf?dl=0
Reply:Hi, i’ve noticed that you seem to have a few manuals for Powcon, you don’t happen to have one for a 530smp do you? I have a one that’s a bit wonky and need to find the fault so i can fix it and sell it on. Thanks
Reply:Not sure if you meant 550SMP or 630SMP, but here are links to both:550SMP630SMP
Reply:Awesome, Thanks ever so much for that!finding documents for these welders is getting quite hard now.  Originally Posted by ArcPowTechNot sure if you meant 550SMP or 630SMP, but here are links to both:550SMP630SMP
GMT+8, 2025-12-18 16:11 , Processed in 0.106890 second(s), 18 queries .
