Snow Removal Equipment, Wadda You Got?
发表于 2021-8-31 23:26:48 | 显示全部楼层 |阅读模式
I use a Gravely, all gear drive with a cast iron Kohler power plant. http://i94.photobucket.com/albums/l1...Gravely007.jpghttp://i94.photobucket.com/albums/l1...Gravely004.jpghttp://i94.photobucket.com/albums/l1...Gravely002.jpgThe snow "cannon" is a 40" unit off a rider I adapted to the quick hitch. http://i94.photobucket.com/albums/l1...Gravely006.jpghttp://i94.photobucket.com/albums/l1...Gravely001.jpgThe splines stripped, so I said the hell with it, and welded the U-Joint to the blower, no more wories.http://i94.photobucket.com/albums/l1...Gravely003.jpghttp://i94.photobucket.com/albums/l1...Gravely005.jpgThis old girl will throw over a foot of heavy wet snow up over the power lines.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Ford 2000 Tractor with a 8'? Fisher plow and "custom" mounting Me!
Reply:My dad has the same set up as you and likes it a lot.Me!
Reply:The best snow removal equipment I found is a So. Cal. zip code.
Reply:Attached Images
Reply:JD compact tractor with bucket and blade. I'll need to get it out in a few hours too...LOLAnything worth doing is worth doing RIGHT
Reply:Tozzi...nice Gravely-Mine is a 1943....She runs great..rebuilt/restored it about 4 years ago.P.S. IT'S FOR SALE !  (cheap plug) -Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:97 Chevy K2500 with 9'1" Sno-Way vee plow and soon a  7'6" SnowMan rear plow.88 K3500 GMC w/ S-W 9'1" vee and 1.5 yd vee box spreader.71 GMC 5500 w/ 5 yd dump body and hydraulic under-gate spreader.JD 400 Lawn & Garden tractor (20 hp) with loader (used to load salt and sand), 6'8" Sno-Way Series 24 blade modified to fit on the loader coupler and needs to get trimmed down a little.Got a spare 8' S-W straight blade and SnowEx hopper spreader that currently needs a truck to ride on, used to ride an 88 S-10 until the truck rotted out from behind/under it.
Reply:Here's my 197? Roper tractor, I've since built a cab for it (complete with overhead console, car stereo & 4 speakers). I also have a snowblower for it. My Dad has an old Gravely...those things are work horses!If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:1953 Case 400 gasser with a custom mounted f17 Farmhand loader and Int. 560 rear tires full of fluid.
Reply:1962 540 Cockshutt and a new sears craftman 30" 15hp snow blower.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:2 choices:http://home.comcast.net/~davidtief/toys/elec2.jpgOr:http://home.comcast.net/~davidtief/toys/dynahoe1.jpgThe second usually wins out - heated cab!DaveUCC305 w/ HW-20Miller Thunderbolt 225Bandsawhttp://home.comcast.net/~davidtief/index.html
Reply:'53 Ford Golden Jubilee with a 6' blade;
Reply:2002 JD GT225 with 4' blade. It moves much snow, and dirt, and gravel. This is when it was new 5 years ago. I've beat the heck out of it since then. Attached Images
Reply:Snow?  What's that?Miller Syncrowave 200MillerMatic 180 AutoSetHobart Airforce 500iVictor O/A (80cf)
Reply:I'm with 700R,  I've heard of the stuff and seen pictures but being that its going to be 78 degrees today I don't think I'll be running out real soon to pick up any plows.MichaelMillermatic 25115" Rockwell Drill Press10" Logan Lathe5hp - 2-stage 80 Gallon CompressorHome Made Sand / Soda Blaster
Reply:A twelve year old! Attached Images
Reply:'99 Diesel 4X4......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:When the Ford tractor does not cut it we bust out the BIG loader...Note: The fence is 8' tallThis thing plows 12' wide with no problem! (also pushes up ANYTHING (cars) that is in the path)Not very good in tight places... Attached ImagesMe!
Reply:What is that an L120, or a 160?Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingWhat is that an L120, or a 160?
Reply:'86 ton dually 4x4 gmc, 9' fisher. It's been sitting idle for a less than a month but from mid Dec. to Mid Jan. it was busy.
Reply:Cub Cadet 10 horse self propelled walk behind. Bought new last winter, just in time to use it at the tail end of our big storm.
Reply:Just got this last month.  Figures I get it ready to go and no snow! Attached Images
Reply:If I want to get serious! Attached ImagesLast edited by spuddown; 02-04-2008 at 08:46 PM.Originally Posted by spuddownIf I want to get serious!
Reply:Now that Cat would put up a good fight ageist the L220 Here Kitty.... Kitty.... kitty....  Me!
Reply:Originally Posted by zapsterHow much to do a driveway with that??...zap!
Reply:My 1955 JD 40C (with an incorrect and very heavy #76 blade):
Reply:ttyR2, that thing is cool looking!  Is that it's "stock" look?Me!
Reply:I used my workboot (while on my foot) to clean the ice build up out of the back of my truck, does that count?
Reply:damn, and I thought I was doing good with an '01 Chev 2500 and a BOSS Power V!!
Reply:The crawler is stock, but the blade is incorrect. It's a #76 and was designed for a JD 1010 crawler. I'm hunting around for the correct #61 blade which is a heck of a lot lighter.
Reply:I've been using one of these for about the last 20 years.  It's called a SnoWonder, and is made in MN.  Don't have to lift the stuff anymore... just push it around and dump it.I have no fiduciary interest in the company.  http://www.snowscoop.com/index.htm Attached Images
Reply:if you guys would just move to the south, you wouldn't need all that equipment. look at how much time you could spend doing other things, like critiquing  my  welds...
Reply:I got a 78' Case 446 with a 48" blower. Kind of looks like a small combine...(click on pic)JD 2210 with loader........DanMy instructor said someone will catch on fire during class...He wasn't joking!!
Reply:Originally Posted by tortisif you guys would just move to the south, you wouldn't need all that equipment. look at how much time you could spend doing other things, like critiquing  my  welds...
Reply:I didn't even know how to use a snow shovel until I joined the army. If it were to snow here in New Orleans I wouldn't be going outside much less on the road with these idiots. I spent 3 1/2 years stationed at the only U S army post in the world with it's own ski lodge so I did get to learn how to use one. It did snow where I grew up in New Mexico but nobody owned snow shovels, county and state didn't even have plows, as it would be gone in a day or two.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:Originally Posted by Jolly RogerI didn't even know how to use a snow shovel until I joined the army.
Reply:Originally Posted by Jolly RogerI didn't even know how to use a snow shovel until I joined the army. If it were to snow here in New Orleans I wouldn't be going outside...  It did snow where I grew up in New Mexico but nobody owned snow shovels...
Reply:Originally Posted by denrepNew Orleans snow plow:Attachment 16960
Reply:Some of the snow we recently received, 50+" in one day: http://microzone.us/weldingforum/ind...g1435.html#newJohn -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneSome of the snow we recently received, 50+" in one day: http://microzone.us/weldingforum/ind...g1435.html#new
Reply:Yep - shovel for those pesky nooks N crannies. A big snowblower and Kubota front wheel loader for the majority of it.  The 'ol lady operates the shovel pretty good. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneThe 'ol lady operates the shovel pretty good.
Reply:She laughed...and agrees!John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by Jolly RogerI didn't even know how to use a snow shovel until I joined the army. If it were to snow here in New Orleans I wouldn't be going outside much less on the road with these idiots. I spent 3 1/2 years stationed at the only U S army post in the world with it's own ski lodge so I did get to learn how to use one. It did snow where I grew up in New Mexico but nobody owned snow shovels, county and state didn't even have plows, as it would be gone in a day or two.
Reply:I was trying to embed a tractor cab video...Last edited by scrapwelder; 03-06-2012 at 12:41 AM.
Reply:whats snow?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:12 year old.  No, I don't have a picture, but yeah!  "GO SHOVEL THE DRIVEWAY!"
GMT+8, 2025-12-26 23:12 , Processed in 0.123102 second(s), 18 queries .
