6010 welding rod
发表于 2021-8-31 23:26:45 | 显示全部楼层 |阅读模式
Hello! Can I use 6010 welding rod for open root pass in plate welding? Such butt join plate welding or 6010 use only in pipe welding? Thanks
Reply:Originally Posted by noel30Hello! Can I use 6010 welding rod for open root pass in plate welding? Such butt join plate welding or 6010 use only in pipe welding? Thanks
Reply:6010 can be used for any open root joint.
GMT+8, 2025-12-26 23:11 , Processed in 0.105042 second(s), 18 queries .
