Welding Rod For 1G Flat Plate welding
发表于 2021-8-31 23:26:43 | 显示全部楼层 |阅读模式
Hello, I would like to know what type of welding rod supposed to use in root pass of 1G plate position or Flat butt joint plate welding, isn't right to use 7018 welding rod or 6010 that use in pipe welding? Currently I apply 7018 for 1G,2G, 3G, 4G plate welding. Is it correct. Thanks
Reply:Im not really sure what you're asking here.Open root, root passes are usually done with 6010 or 6011. If it doesn't have to have 100% penetration, 7018 would work.[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:yes its for open root pass.
Reply:With the proper joint prep either one will work. You don't say what thickness of plate you are welding, though, which may make a difference. Is this for practice, a test, or what?
Reply:Either. Open root, back weld, or backing weld?The last 2 make it pretty darn easy!
GMT+8, 2025-12-26 23:11 , Processed in 0.116197 second(s), 18 queries .
