bullet hinges ???
发表于 2021-8-31 23:26:43 | 显示全部楼层 |阅读模式
anyone know what the weight rating is on 4 inch hinges ive looked all over and cant seem to get a weight on any of them ??350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Here you go, pages of hinges with weightshttp://www.kingmetals.com/Default.as...&CurrentPage=2Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:ok i must be missing it cause i dont see any weight ratings listed just the weight of the hinge itself350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Got a part number there weight limit is there book catalog
GMT+8, 2025-12-26 23:41 , Processed in 0.095921 second(s), 18 queries .
