Backing Plate Brake Stuff..
发表于 2021-8-31 23:26:35 | 显示全部楼层 |阅读模式
These go to a brake system on a front end loader...I think..The backing plate was about 16" in diameter so whatever it is is BIG..The were welded on the positioner so there was no stops and starts...045 70S-2 filler..3/32" red..You know the story.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Sweet!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Do you have speed control on that positioner Zap? Like foot pedal I mean, so you adjust as you rotate, or do you set it, and forget it?
Reply:Originally Posted by daddyDo you have speed control on that positioner Zap? Like foot pedal I mean, so you adjust as you rotate, or do you set it, and forget it?
Reply:Was a continuous weld required? Or is that your preferred method? Awesome job, as usual."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:as always, looks beautiful zap!
Reply:Originally Posted by Stick-manWas a continuous weld required? Or is that your preferred method? Awesome job, as usual.
Reply:Now that's sculpture!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Looks good, I can't figure out what it is.   Doesn't really matter.  Nice work.   Ah yes, tig foot pedal on right, positioner pedal on left, filler in one hand torch in the other.    Its fine if I don't think about it.Real world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-26 23:15 , Processed in 0.097887 second(s), 18 queries .
