some new jobs i've done
发表于 2021-8-31 23:26:34 | 显示全部楼层 |阅读模式
here are some pics of some jobs i've recently completed on is a roof access ladder i didn't get a pic with the safty cage on yet i will post that as soon as it gets back from the powder coaters, the other project is old style barn hinge and thumb latch pull handle the a small project of a roller extention to a boat Attached ImagesLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:here are a few more pics of the pull handles and hinges Attached ImagesLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:It all looks good except you thumb hole on the handle.  the square hole either has overcut or a pilot hole cut that was too proud.  I think the hinges are nice and I like the safety gate on the ladder.  If the ladder is required to have a safety gate, is it also required to have a mancage?  I don't have the code infront of me, but all the ladders I built were required to have them (mine were industrial/oil refinery/oil field installation)
Reply:Nice work
Reply:That Door Handle is 'robust'!  Very Nice indeed...I like the fit-up on the Boat trailer for the tinner, that's pretty sweet.  I wonder too, if anyone noticed the 'Bird Poop' holding the Tow-Hook together?  Yikes!(I also realize that's not your weld  )Cheers,Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:Originally Posted by Scott YoungIt all looks good except you thumb hole on the handle.  the square hole either has overcut or a pilot hole cut that was too proud.  I think the hinges are nice and I like the safety gate on the ladder.  If the ladder is required to have a safety gate, is it also required to have a mancage?  I don't have the code infront of me, but all the ladders I built were required to have them (mine were industrial/oil refinery/oil field installation)
Reply:here are a few more pics of other stuff as well as the ladder all complete. the one is a beam bracket for a house, then  couple of brackets for a neon sign then the ladder Attached ImagesLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:Nice projects. Not to steer away from anything but is that a washing machine in the back on pic #1 ?  Parts washer?.....Miller Dynasty 200Millermatic 211Instagram?.... find me @ WELD_MEDIC
Reply:Originally Posted by heimbuckweldingAs far as the hole for the thumb latch it had to be that size to slide the handle through thats how the original one was that i had to go from and it was like that from the factory.  the original one was stamped out of thin sheet metal I made mine from heavy duty steel the customer wanted a robust look.
Reply:oh i see what your saying that was from the plasma cutter when it percied through the steelLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
GMT+8, 2025-12-26 23:32 , Processed in 0.064301 second(s), 18 queries .
