Donation "Lock Box"..
发表于 2021-8-31 23:26:33 | 显示全部楼层 |阅读模式
I was told the open side is where a chute will be installed..If that was not the case then this would make no sense at all..The box is made from 3/16" HRS...045 70S-2 filler..200 amps max..3/32" red..One more post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Few more..This is for a church and will be located in the basement..The old wooden one got broken into so now its time for steel..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Amen!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:It's just a sad world when you have to do stuff like this for a church. Stealing from a church, there is a good way to get struck by lightning. Good work as always Zap!kidtigger24  They think I’m crazy, but I know better. It is not I who am crazy. It is I who am MAD!
Reply:Originally Posted by zapster.045 70S-2 filler..200 amps max..
Reply:I'm guessing the small wire will melt faster thus minimizing the amount of heat needed to weld. ???Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by DemonSpeederI'm guessing the small wire will melt faster thus minimizing the amount of heat needed to weld. ???
Reply:....but he's already using enough heat to melt the 3/16 corner joint at 200a.That would easily take care of a lot thicker filler rod and I think the thickerfiller would help cool the bead if that was the case. I'm hoping it's some secret experimental technique that will help lead me tomy next 'AHH HAAAA' moment. How do you know the blacksmith's dog? When you hollar at him he makes a bolt for the door!
Reply:Ugh, well that's embarrassing lol.Can't I just delete my previous reply?Dang I still have a lot to learn.**Thanks zap.Peddling back and using the little wire, I'm still getting closerto my ah ha moment! **How do you know the blacksmith's dog? When you hollar at him he makes a bolt for the door!
Reply:Nice ZapI made a lot of drop safes when i worked for a safe companyBut they were for convenience stores etc 1/4 plate, piano hinge, time locksall mig weldsBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by kidtigger24It's just a sad world when you have to do stuff like this for a church. Stealing from a church, there is a good way to get struck by lightning. kidtigger24
Reply:That'll work. Getting tough around here with theft too. Someone asked me about a former employee that was my sons caregiver, told him that she came to work with a hammer. Ya know the old saying- steals anything not nailed down. PeterEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:Zap,Looks to me like the box needs a shelf to keep one from just sticking his hand in the box.Shelf on a angle which doesn't extend all the way to the rear of the box would allow money to "drop in" but would prevent someone from just reaching in.Man, you don't need any more tig practice.  You got to get a mig.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Looks to me that Zap's simply showing what the church wanted him to fab. His welding skill is not in question... so one fabs what is asked. I really enjoy seeing his tig welds.DannyMy SiteJust worrying 'bout what I can't get to today.
Reply:Originally Posted by The_BlacksmithLooks to me that Zap's simply showing what the church wanted him to fab. His welding skill is not in question... so one fabs what is asked. I really enjoy seeing his tig welds.
Reply:Zapster, that's one good looking box and I'm sure up to the job. There is one area that looks very weak and I would like you to test it. I think it would take about a minute to get into it and without any noise.I did this with another porject that used larger hinges than what you used. A large set of channel locks will unroll the hinges from around the hinge pins, and hasp, then you can lift the top off. In my project, I over stressed the hinge and straighteded the rolls out, I then used channel locks to wrap the hinge rolls back around the hinge pins, and welded the rolled portion back to the hinge flange. It will be ten times stronger.Try a large set of channel locks and see if you can unroll the rolled portion of the hinge from around the pin.
GMT+8, 2025-12-26 23:14 , Processed in 0.099585 second(s), 18 queries .
