What's This Old Thing? Too Dated to be Useful/Valuable?
发表于 2021-8-31 23:26:31 | 显示全部楼层 |阅读模式
Hello,Truth be told I purchased a storage unit and found this within.  I know nothing of the welding world and thought I would come to the experts to find out what this is and what it might be worth since I will probably decide to sell it.Is it too old to be safe or is it technology too dated to be safe to sell to someone?  How would you describe what I got here in a Craigslist ad?  What would you ask for it?Thanks for any input!
Reply:It's a small Oxygen-Acetylene torch kit, or "plumber's torch kit"  if you will (due to the small tanks). A better picture of the gas regulator body (under the gauges) would help identify maker, as would a picture of the actual torch."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:You might get $100 or so for it if everything works and the hose ain't rotted out. Nothing inherently unsafe about it just because of age.
Reply:Well, at least the hose says DAYCO and is printed in English.  "USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Sears rig from the eighties. Victor type. May be US made by Victor for Sears (transition times back then).Dust it off and write everything down. eBay it for local pickup only. Start the bid at $75 and watch the plumbers/appliance-AC guys chase after it.Craigslist is a scumbag gathering production.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Check the date stamps on the tanks, they might be due to be hydro tested, Other than that it looks like its in good shape, the HVAC guys will like it.
Reply:Originally Posted by ironmangqCheck the date stamps on the tanks, they might be due to be hydro tested, Other than that it looks like its in good shape, the HVAC guys will like it.
GMT+8, 2025-12-26 23:13 , Processed in 0.093069 second(s), 18 queries .
