Bend test AWS D1.1 Question
发表于 2021-8-31 23:26:30 | 显示全部楼层 |阅读模式
The book isnt very clear on this, or maybe I am over thinking it. So heres the deal  (3/4" V grove SMAW, with backing (7018). What I can't figure out is the width the plate needs to be for a side bend. D1.1 refers me to figure 4.13, the figure says 3/8, however on the little table below it states that 3/8-1-1/2" equals ( T ). so t=T. . . with that said, I would assume that the strip needs to be 3/4", However I measured my Test bend coupon from another certification which was (Flux core on 1" plate with backing), and that was 3/8ths.... so the number I keep running in to is, 3/8ths.... any input would be appreciated.
Reply:The "thickness" is 3/8"-----------the "width" is the thickness of your plate, which in your case is 3/4"--Matt    I test my guys to D14.3 which is the same thing except the thickness is 1" instead of 3/4"6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:So cut two "slivers" 3/8th thick,  adding 1/8th to each side for thermally cut coupons. Correct?
Reply:yep---------thermally cut you need to add an 1/8" on each side of the "sliver"--------mechanically cut you don't.Last edited by ExpatWelder; 11-05-2013 at 11:42 AM.Reason: messed up, didnt read the post6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:This may clear things up a little Attached ImagesLast edited by ExpatWelder; 11-05-2013 at 11:14 AM.Reason: jjjjasdkjf;asjf;aj6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Expa where was this page in D1.1? :-) lol I can't find it. I have the 2010 version.
Reply:Page 165 in the 2002 book6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
GMT+8, 2025-12-26 23:11 , Processed in 0.106700 second(s), 18 queries .
