6011 rod motion
发表于 2021-8-31 23:26:26 | 显示全部楼层 |阅读模式
I just got an old 220v Craftsman buzzbox, and some smaller than 1/8" 6011 for free. It is my first attempt at welding outside of the 2 courses I took at the local VOTEC.I began learning stick on an Idealarc, mostly DC+. I prefer the wheel over the digital; I feel it makes me more in tune with my puddle as I adjust to the change in workpiece temp on multiple passes. I can most likely pass a 3/8" flat test, according to the instructor. I did a lot of 7018, and 6010. I actually like 6010. I am told this is not "normal" hehe.Do I use the stop, pull away and go back 6010 motion, or a steady motion for stringer beads?Are 6011 rods suitable for root pass gap or no?What are my chances of using this to install a welded cat-back exhaust system on my Jeep? I know I'll need a less penetrating rod, probably ss. Suggestions? I can borrow a 120v MIG, but have never shot wire. Yet.
Reply:6011is the one rod that can be ran in a whip method to make sawtooth type weld beads.  a bit like the stack of dime tig welds but sharper edges on the dimes. use some 1/16" 6013 for your exhaust,  harbor freight carries it too.  it works real nice for doing thin stuff around 20-40 amps.  I recently welded up a hot water pressure washer coil for a buddy.  had to stick cuz it was the only thing that would fit in between the coils. just ran a bunch of overlapping beads.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Thanks for the reply. I have read 6013 is a good fit for the application. I am concerned about rust out though.
Reply:They make a special paint for welded exhaust pipes that is supposed to help. The small mig would work too, nice for tight areas. Just get some scrap pipe and practice.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
GMT+8, 2025-12-26 23:14 , Processed in 0.099318 second(s), 18 queries .
