gate hinges made from concentric pipe
发表于 2021-8-31 23:26:13 | 显示全部楼层 |阅读模式
Hello there, had some pictures somewhere of a few that I have seen out there but can't find them at the moment.  Basically the post pipe has larger diameter pipe welded on the outside for collars then the part for the gate that is the same size becomes the hinge and rests on the collar.  I've seen a few with welded on grease fitting bungs and that seems pretty slick.  I was wondering if there's any tables anywhere which has the inner and outer diameters listed so I can select the sizes that will fit best.  Thanks
Reply:The ones with the grease fittings are generally pre machined weld-on hinges You can buy them online. They work great provided you align them properly and put sound welds on them.http://www.marlborohinge.com/weld-on-hinges
Reply:http://www.steelservicesinc.com/SSI_..._Book_2007.pdfI think this is what you're after, go to the section on tube and pipe, they don't have a list that says X" tube fits over X", but you can compare and do the math to come up with your answers.I've made a few like this but don't have the b.o.m. handy.Be sure to leave some clearance and beware that the seams may give you clearance issues,Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:dont have to fit that tight to work well, you can drill and tap for the grease fitting..
Reply:-The inner weld seam is readily removed with drum sander.-.020+ total clearance between the inner pipe and outer,in pipe sizes 2" and larger is not excessive. Grease fillsthe clearance gap.-Use brass/AL shims to space and center the inner/outerpipe sections during fitup and alignment; then remove the shims.Failure to do the above, creates mis-aligned hinge assemblythat is bound up.Attached pics are of hinge assemblies using modified pipe,but not using the hinge post as a center hinge pin (as you are describing). Using the hinge post-itself, as the center hinge pin, works well, is stoutand durable with: -adequate inner clearancing that is maintained via temporary shimming-selecting a large enough pipe for the center hinge pin that will notunduly deflect during gate operation, is firmly anchored/embeddedinto the ground.http://weldingweb.com/attachment.php...1&d=1330630111http://weldingweb.com/attachment.php...1&d=1330630130 Attached ImagesBlackbird
Reply:Another way to skin this cat is use DOM, pretty much minimal seam, so doesn't need any ID fiddling around..02 tolerance is good info...thanks.Last edited by fredschrom; 03-29-2012 at 06:59 PM.Reason: spelling
GMT+8, 2025-12-27 03:09 , Processed in 0.138109 second(s), 18 queries .
