7018 DCEN good for galvanized?
发表于 2021-8-31 23:26:09 | 显示全部楼层 |阅读模式
Anyone ever use straight polarity to burn though galvanized w/ 7018? My thought is that by throwing the heat into the work peace with a slightly longer arc @130 amps I can burn off more galvanizing making it much easier to weld. I know it's "technically" wrong but if I'm getting good penetration and the weld looks good?...
Reply:If you are unable to grind the galv off and you are using 7018 I suggest just welding it reverse polarity like usual. Long arcing 7018 will give you porosity and make it hard to control, don't know what straight polarity does with 7018 because I have never tried it.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:To answer your question simply, no. If welding through galvanized and to ensure the "best" results (less porosity, contamination, best penetration & fusion) use 6010/6011. Just my opinion and experience with zinc. "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"-JodyIdealarc 250 "Fatman"MM 252MM 211 "Little boy" Victor Torches
Reply:Ive tried it once   welding (Hot) somewhere between W.T.F.? and Nuclear!     Wellding galvi chain to plate.  After I was done It slid right off when I picked it up.  2nd time it worked cause I had burned the galvi off.Go with 6010“I'm going to do the thing that God put Galen Beasley on this Earth to do:Have Salon quality hair and weld.Nothing like a good cup of coffee and the smell of 6010 burning in the morning. 971-204-3444 cell API ASME Structural NDT and Repair
Reply:Originally Posted by galencwiIve tried it once   welding (Hot) somewhere between W.T.F.? and Nuclear!     Wellding galvi chain to plate.  After I was done It slid right off when I picked it up.  2nd time it worked cause I had burned the galvi off.Go with 6010
Reply:Originally Posted by SomthingoriginalAnyone ever use straight polarity to burn though galvanized w/ 7018? My thought is that by throwing the heat into the work peace with a slightly longer arc @130 amps I can burn off more galvanizing making it much easier to weld. I know it's "technically" wrong but if I'm getting good penetration and the weld looks good?...
GMT+8, 2025-12-27 01:21 , Processed in 0.068962 second(s), 18 queries .
