welding stainless
发表于 2021-8-31 23:26:09 | 显示全部楼层 |阅读模式
I am in the process of hopefully welding some sch 10 11/2" stainless piping with my Miller 130 volt MIG welder. I need some help on what wire I should use and what type of gas should I use. This is 316 stainless
Reply:ER 316 WireSome would say 90% He, 7.5% Ar, 2.5% CO2I like to use 98% Ar, 2% CO2If you're going to use the first gas, you might be able to get away with 0.030" Diameter wire, but I would probably use 0.023" for that small of a machine.
Reply:thanks
GMT+8, 2025-12-27 01:21 , Processed in 0.070620 second(s), 18 queries .
