Good books explaining Tig pipe test ?
发表于 2021-8-31 23:26:06 | 显示全部楼层 |阅读模式
I want to start practiceing for taking the 6G pipe test in steel and/or aluminum.I have been able to find some info on-line about how the steel senario goes, butI have not seen much on whatever the aluminum pipe test looks like.   ( for instance-is it done in one pass or multiple ones like steel ...)I can do the normal garden variety welds like lap, fillet, butt, outside corners.....the normal welds I use building things.  Can yall reccomend a good online resource or even better- a good advanced textbook ?I have been practiceing with 6010 stick because it has been 25 years since I used any !I am thinking of Tig root and then stick overtop but might consider stick/stick later.Everybody that wants to hire a Tig welder seems to want a 6G cert even if it has nothing to do with the kind of products they are making.   So I guess the piece of paper wouldhelp me.   Just missed a job because I didn't have it.Tim
GMT+8, 2025-12-27 03:09 , Processed in 0.103521 second(s), 18 queries .
