Hey Everyone, Here are some pics of a bracket I made to convert a Polaris tow bar to a Arcitic Cat 4wheeler. The customer wanted to be able to remove it easily when not using it and also have the winch capabilities. Attached Images
Reply:Looks like if you flipped the bracket over, where the towbar mounts lower, the bracket could be left in place and still use the winch. Kinda hard to tell since the pics are somewhat dark in that area. Might only need a small modification to make it work that way anyway. But if the customer is happy with it, I guess I am too, but he wouldn't have to mess with putting it on and taking off so much.
Reply:Bistineau, Thanks. I did not do a very good job explaining it to remove the bar you just have to remove two pins not in the pics. the guy can still use his winch after he pulls the pins and not the bracket. Thanx Dale |
