Here is a spool rack i made out of scrap. i made it to hold my mig spools. i will bulid a bigger at some point Attached ImagesMillermatic 211 with mvp plugs miller titanium series welding helmetstihl chain saws 8 ft welding table
Reply:Good use of scrap, but I hold a few reservations:1) Your spools will collect dust which can clog up your drive - most likely not going to happen but still a possibility.2) Your rack does not have any gussets or bottom supports so your torque arm is quite long. You are putting all the weight on the mounting bolts in the wall. Put more weight on it and it will probably rip out of the wall. Take note of the shelf above it how bracket height equal to shelf depth.3) Where your mount attaches to the wall, I would suggest at least 4 fasteners to attach it to the wall. |
