Latest Project....Grizzley
发表于 2021-8-31 23:26:05 | 显示全部楼层 |阅读模式
Latest project I just finished, a grizzley.The bottom framework is 4 x 4 x 1/2 angle and 4 x 4 x 3/8 HSS with 4 x 1/2 flatbar diagonals. The upper framework that supports the screens is 3 x 6 x 1/4 HSS. The actual screens are salt hopper screens that were never used and I adapted them to fit in the framework.Product is dumped on top and gravity does the rest...hopefully. If not the, top is hinged using 1 3/8" x 2 1/2" MT with a 1 1/4" dia. pins so the loader can pick it up and give it a drop, that's why there's 4 springs under the front edge This ones going to be used for reclaim, rack, recycled asphalt whatever you want to call it to get rid of the big lumps as well as salt in the wintertime to try  and keep out the trash (rocks, sticks etc). The last one was mutilated by an operator using the bucket to try and beat the lumps down thru....duhhhh.This is the forth or fifth one I've made, takes about 110 manhours total......Mike Attached Images
Reply:You get all the fun jobs!!What does it weigh?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:What does it weigh?
GMT+8, 2025-12-27 03:18 , Processed in 0.095392 second(s), 18 queries .
