Made up a few socket holders for the top of my toolbox today. Not much welding done, just some plug/tack welds but I figured I'd post them anyways. These are for the sockets I use most often that sit up top rather than in a drawer. 1/4", 3/8" and 1/2" Mostly metric, only 6 deep sockets are standard. Now who took my 11mm 1 1/2" x 1/4" for the base for 3/8" & 1/2" sockets. 1 1/4" x 1/4" for the base of the 1/4" sockets. And well you can probably guess the measurements of the round stock used..Used 3/16 stamps for the numbers. They are all clearly visible, the camera and lighting makes some look not so good.Sneak peak at the top secret manufacturing processI think I'm going to make one more to put some standard sockets on even though I don't use them often. I know, I could have bought some holders like normal people do but I like mine better I think I'm going to try the coating method using heat and oil that I was reading about in a thread on here not long ago. What kind of corrosion protection does burning oil on steel give? I should probably look into that before I go ahead and do it.I'll post up another pic once I decide on what to coat them with and once they are put back in the toolbox.
Reply:Nice idea.Will Supports Autism Awareness My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Great idea, those look great I bet they won't crack or break like the plastic ones I keep replacing...... I am stealing the idea. Thnk youM.
Reply:How are the pins held in? You might try painting them a dark color and getting a lacquer paint stick and highlighting the letters. P.S I would buy a set.
Reply:Originally Posted by BlindViperHow are the pins held in? You might try painting them a dark color and getting a lacquer paint stick and highlighting the letters. P.S I would buy a set.
Reply:Those are about the nicest socket rails I've seen. I just use these from Snap-On. I need them to hold the socket on, so when I bring a rail to the vehicle I'm working on, they all don't fall off."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Thanks guys! Originally Posted by BlindViperHow are the pins held in? You might try painting them a dark color and getting a lacquer paint stick and highlighting the letters. P.S I would buy a set.
Reply:Originally Posted by Stick-manThose are about the nicest socket rails I've seen. I just use these from Snap-On. I need them to hold the socket on, so when I bring a rail to the vehicle I'm working on, they all don't fall off.
Reply:Damn, those are nice! I just took the standard socket holders and made a metal frame for them so I didn't have to drill into my toolbox!Miller Performance AD Helmet - Camo Edition Soon to have: Jackson HSL 100 - Forest Digi CamoMiller Thunderbolt AC/DC((Currently at welding school))
Reply:http://www.mechanicstimesavers.com/s...ct.asp?catID=1then there's everything else.
Reply:Originally Posted by cd19http://www.mechanicstimesavers.com/s...ct.asp?catID=1then there's everything else.
Reply:magnatize them and then the sockets might stay put.
Reply:Think they are heavy duty enough? Probably should've used T1.Stick-man, I've had better luck with the Harbor Freight rails than the SnapOn.Millermatic 200Hobart Handler 120Victor O/A & Ramco BandsawLincoln 225 ACSnapOn AD HoodMiller XMT304/22AHypertherm Powermax 1650 G3Lincoln Idealarc DC600 w/Extreme 12 VSMiller Digital Elite "Joker"
Reply:Your socket trays are a nice idea. They look similar to ones that I have been making and selling for years. The problem is that they are time consuming to make and no one wants to pay for my time when they can buy the plastic ones on sale for a smaller price. Everyone seems to love cheap chinese crap. Just a suggestion though, from my experience the short pins would not hold the sockets in place if the trays were bumped, so I switched to making them all with long pins and also found it much easier to place the sockets onto the long pins. Also I always bevel the top of the pin so that there are no sharp edges and also makes socket slide on a bit easier. Once again making the pins becomes very time consuming. Also I like to make the trays hold more sockets than the plastic ones, and I always have the socket needed for the job.Also I make wrench racks for SAE and Metric wrenches, once again people liked them but wouldnt pay for my time to make them.Any ways happy to see other people experincing the joys of making things for themselves. These are things that will be in our tool boxes for a lifetime and beyond.
Reply:Nice...something I need to do. Are the numbers just stamped?
Reply:Originally Posted by RaptorDunerThink they are heavy duty enough? Probably should've used T1.Stick-man, I've had better luck with the Harbor Freight rails than the SnapOn.
Reply:oatsy I meant to ask if you were on vacation from the logging job up in alaska?
Reply:the who in the what now? I know its late and I'm tired but did I miss something lol? I've been known to clear some trees before but I don't recall ever being in Alaska.
Reply:"Coatsy" on the show AxeMen.Millermatic 200Hobart Handler 120Victor O/A & Ramco BandsawLincoln 225 ACSnapOn AD HoodMiller XMT304/22AHypertherm Powermax 1650 G3Lincoln Idealarc DC600 w/Extreme 12 VSMiller Digital Elite "Joker" |
