fix it ?
发表于 2021-8-31 23:26:03 | 显示全部楼层 |阅读模式
would you fix this dump bed or just start over and build a new one Attached Images
Reply:I would start over,there is usually at least 3 times as much rust that you can't see.
Reply:Holly crapo... I would say since the rest of it appears to be soild... I would try to fix it... but that's just judging it by these pics..Last edited by DemonSpeeder; 03-31-2012 at 08:25 PM.Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:new one-NateMiller Trailblazer 302gMiller Spoolmatic 30aLN-25 x 2Idealarc SP200Hypertherm Powermax 600
Reply:You can't fix what's not there..New one time....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterYou can't fix what's not there..New one time....zap!
Reply:may be easier to just replace. go to the junk yard and cut a section of bed floor out and make sides...done.
Reply:hi, here is craigs list. http://www.allofcraigs.com/2009/08/s...as_epq=&as_eq=
Reply:New one, aluminum diamond plate"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:new one. you will have double the time in fixing it than you would with building a new one.
Reply:new one and with pictures
Reply:New one gets my vote.Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
Reply:he wants it fixed. so it begins Attached Images
Reply:Whatever the customer wants, some want a hack and slash cheapo repair, others want new and good. It all comes down to the guy paying you, I don't argue anymore.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:more pics. Attached Images
Reply:Show the customer this one. .125 5052. aluminum , Attached Images
Reply:thats nice how much
Reply:thats a nice bed, to bad the rest of the rig is going to crap... Ed,like grandpa always said. "You can't fix stupid". So fix what you can and move on. personally, I think it's stupid to fix that. But like it's been said, you do what the customer wants. Even if it's stupid.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:you gotta do what ya gotta do. he has a 50 acre farm in sebastianand more work is on its way. so i do what he wants. the 20+ yearold weld pak still welds better than the mm251 on sheet metal Attached Images
Reply:Hey man, good job so far! And it's a job and thats what your getting paid for, so keep it up. I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by ed macthats nice how much
Reply:how much would a used or new one have cost?
Reply:this is what he wanted.so i did it Attached Images
Reply:Job well done.
Reply:my guess is it's hard to break old habits mick.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stingergood job.
Reply:its just nice here this time of year and still working in the shadei have a 60" cealing fan going in before it get to hot (end of may)and yes im trying to make the floor last as long as i canthanks guys
Reply:Those old Weld-Paks have made MANY auto body shops a LOT of money.
GMT+8, 2025-12-27 03:10 , Processed in 0.103635 second(s), 18 queries .
