Miller Maxstar 150 tig torch adapter help?
发表于 2021-8-31 23:26:01 | 显示全部楼层 |阅读模式
Ok, Say I wanted to hook up a water cooler for a miller maxstar 150. What adapter would I need to make the water cooled torch work being that the maxstar 150 uses a flow through port in the dense connector for the gas. I was looking at a 20 series water cooled torch setup. All these adapters I looked at got me confusedYa gotta spend money to make money!
Reply:You have to buy the water cooled Dinse connector with the water connection. Then thread the water cooled power cable to it, and the water cooler hose to the side. Your water cooled torch gas line goes right into the machine. See CKworldwide for parts. I recommend you buy the dinse connector with the fuse block installed. That way if you forget to turn on your cooler, the fuse will melt before you cook yourself with a melted power cable.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonYou have to buy the water cooled Dinse connector with the water connection. Then thread the water cooled power cable to it, and the water cooler hose to the side. Your water cooled torch gas line goes right into the machine. See CKworldwide for parts. I recommend you buy the dinse connector with the fuse block installed. That way if you forget to turn on your cooler, the fuse will melt before you cook yourself with a melted power cable.
Reply:Call up HTP and tell them what series torch you want and what machine you have.  You will get just as good of deal there and they will send you what you need.
Reply:Why a water cooled torch on only a 150 amp machine?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
GMT+8, 2025-12-27 03:20 , Processed in 0.110149 second(s), 18 queries .
