step back in time.
发表于 2021-8-31 23:25:56 | 显示全部楼层 |阅读模式
1929 welding text book, Kinda cool to look at all the old machines and litrature from those years. Interesting for those who enjoy this kind of stuff!http://archive.org/stream/electricwe...ge/n1/mode/2up
Reply:Cool Stuff! Thanks for sharing that...We had an old Westinghouse motor-generator machine at the plant where I started. It was ancient when I got there and it looked almost like the one in that book!
Reply:times have most certainly changed!
Reply:Have some old books on machining.  They're also very interesting.  People always found a way to do things."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Come to where I work..You will truly be "Back In Time"......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Just read about the La Grange Hoho process - fascinating stuff
Reply:The Lincoln on page 49 looks a lot like a "nude" SA-200. GeorgePrincess Auto "PowerFist" Dual MIG-136, WF & cap modGas Powered Alternator Welder (being rebuilt)
Reply:my great grandfather was a welder in those days, and did alot of bare wire stick welding which of course as you guys know wouldnt yeild the most "sound" welds haha. He said as time went on they started experiementing with all sorts of coatings and the first actual cullositic type coating was literally newspaper wrapped around the rod in a type of "paper machet" type consistancy and then dried. Told me of stories of welding up pipelines all with oxy/acet. I have alot of respect for those guys thats for sure!
GMT+8, 2025-12-27 03:18 , Processed in 0.118180 second(s), 18 queries .
