Sample welds from Thermal Arc 181i
发表于 2021-8-31 23:25:56 | 显示全部楼层 |阅读模式
I have had several ask how this little machine welds. I ran a test piece with MIG and a piece with 1/8 7018 and 3/32 6013. Its been a long time since I did any stick so dont slam me to bad.The stick welded very nice, stable arc that was controlable and seemed to keep a even heat was running about 130 amp on the 7018 and about 80 amp on the 3/32 6013. I can find no dislikes about this machine so far.
Reply:Hey bhardy501, glad you finally posted some results from your new TA181i... I suspect a lot of folks like me were waiting... knew the machine had arrived yet it remained quiet for some time.  Sounds like you like it. Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:I apologize for the wait but I ended up in the hospital being very dehydrated and it has taken me some time to get over it. Hope the pics help, even with my chicken scratch welding.
Reply:Ah come on... don't give me that...  ... You was building a welding rig CART! Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Its on another post. I finished it today.
Reply:Relax bhardy501.  I know that... I was just pulling your chain. I enjoyed both posts. Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Its all good.
GMT+8, 2025-12-27 03:18 , Processed in 0.094334 second(s), 18 queries .
