custom fire ring project
发表于 2021-8-31 23:25:53 | 显示全部楼层 |阅读模式
Something I have been working on.26" dia. 14" high10g steel.CNC plasma cut.All welded construction using 1/8 7018-1Aprox weight: 50lbs.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Looks great. That is something else I have to add to my list of to-do projects.Dave ReberWadsworth Ohio
Reply:I used high heat bbq paint (650f). It will be interesting to see if it holds up to the fire heat.I don't have a metal roll thus the reason for a 6 sided ring.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:You spelled "Cubs" wrong.   Otherwise it's cool.__David Hillman
Reply:Was it supposed to say "Cubs"?  If so, that is a huge mistake.  I could see "Cubbs", but Cobbs??
Reply:Really nice.  Only one problem.  The side with the Vikings cut into it will probably flame up really hot, then retire, then make you think its comeing back, then retire, then come back..... and repeat.
Reply:Originally Posted by mattlagoReally nice.  Only one problem.  The side with the Vikings cut into it will probably flame up really hot, then retire, then make you think its comeing back, then retire, then come back..... and repeat.
Reply:How has the high temp paint held up on these?
Reply:Nice job, and it doubles as a floor stencil.HammerFile Big Hammer------------------------------Here, let me Google that for you...
Reply:Originally Posted by David HillmanYou spelled "Cubs" wrong.   Otherwise it's cool.
GMT+8, 2025-12-27 01:30 , Processed in 0.072828 second(s), 18 queries .
