En 15614-1 fw single run throat thickness
发表于 2021-8-31 23:25:53 | 显示全部楼层 |阅读模式
Hello,I am creating a WPQR according to 15614, It's a single run process and I need to calculate the throat thickness. For single run,throat thickness shall be "0,75a to 1,5 a" but I couldn't find anything related with the "a" in 15614. How am I supposed to calculate "a" ?  Thank you best regards
Reply:For throat thickness; a max = 0,7t   a min: √tmax - 0,5. Should I use the average value of "a max and a min" ? Thanks
Reply:maybe this is something for you Attached ImagesBS EN ISO 15614-1-2004+A2-2012.pdf (61.2 KB, 229 views)
GMT+8, 2025-12-27 01:30 , Processed in 0.134769 second(s), 18 queries .
