Did i get a good deal or not? Miller coolmate 3
发表于 2021-8-31 23:25:52 | 显示全部楼层 |阅读模式
I picked this miller coolmate 3 up today for $350.00. It runs fine, no bad noises and it pumps. I'm going to flush it out with some distilled water just to be safe. There was no coolant in the tank. This was looked over and checked out by a welder repair business, so im assuming everthing should be ok. It looks pretty clean inside. The outside cover has a fresh coat of paint on it. I see it looks like one hosees was replaced. I had the guy test run it before I bought it. I didn't see any leaks, but I guess you got to let it run awhile also. Good deal or bad deal? $350 seemed had to pass up.Ya gotta spend money to make money!
Reply:Just ran 7 gallons of distilled water through it to flush it. Everything seems to be fine.Ya gotta spend money to make money!
Reply:As long as it don't leak and it all works it sounds like you did goodBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Man did you get TAKEN!Send it to me so you're not reminded of the bad experience every time you look at it.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Wow that is in great shape. You got a deal alright. I have the same one, but painted black on the cover. For years it would work for a couple of hours, then the motor would over heat. Never figured it out until I discovered the pressure was too high overheating the motor and tripping the thermal overload switch, thus destroying a power cable. So I removed the acorn cap on the right side of the side of the ProCon pump, unscrewed the pressure screw some to relieve the pressure and replaced the acorn cap. All is well.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2025-12-27 01:31 , Processed in 0.091907 second(s), 18 queries .
