Reed switch
发表于 2021-8-31 23:25:51 | 显示全部楼层 |阅读模式
Just recently purchased a 62 model sa 200 and an idle upgrade kit for it was wondering where the reed switch mounts. Have a good idea on everything else. Any help would be appreciated. Thanks
Reply:Depends on the reed switch some go on the positive lug some go on the negative lug
Reply:I purchased it from welder parts whare house. Come with some instructions it shows a wire going from board to the 110 plug ground. Just don't know which lug to mount it to has a copper strap wiyh holes in each end and a bolt through one hole.
GMT+8, 2025-12-27 01:39 , Processed in 0.104112 second(s), 18 queries .
